I believe this is done in drag racing to ensure 50/50 drive always, as you are going straight on only, and in drifting as it's allot easier to spin the rear in a car with no differential.
What he said, although in theory, if the ABS works properly being able to properly threshold brake wouldn't require removal of the system.
Some people thinks it's either too aggressive, or not aggressive enough or something, and don't want the extra weight.
ABS means not losing traction completely
, and thus being being able to steer whilst,
breaking with force enough to lock the wheels.
ABS doesn't help you brake, it prevents you locking the wheels, and is only meant to only kick in at the very extreme, when you've overcome the friction your tyres have with the road.
Yup, but for SW20's it's only designed for the open diff rev1 turbo box.
It'll work in other E153 revs if you swap the plastic speedo drive, and I believe a couple of bolts.
I don't think there's one available for the S54.
I will do this ASAP.
P being in like 2 yrs.
![Sad :-(](./images/smilies/icon_sad.gif)
buying a house has ruined my car plans.
From all the review's I've read, they work very very well, in pretty much everything.
Clutch based LSD's are A very grabby and B have consumable, wearing parts.
They are adjustable, but you have to remove and tear down the box to adjust them.
But they are 2 way, which helps if you expect to have a wheel of the ground at any point.
[/quote]
