The timing has been checked and checked again by a chap with extensive knowledge like you, so it's not that.
Where could the air leak be coming from?
I'll do the other checks when my g'box has been replaced at the weekend.
SuperRedMR2 wrote:
When the engine up to normal temperature, it idles around 1000rpm, I took the inlet hose off and covered the hole and the revs dropped considerably.It was stuttering a bit.
So?
PW@Woodsport wrote:The Waxstat will always flow some air past it even when fully warm and working as it should be.Of a typical 900rpm idle I'd say a good 600rpm of that is air going past the waxstat valve, the additional 300rpm being added by the air bleed screw.
A Mk1 will cut out or come very close to stall with the bypass hole covered, so I honestly don't think this is an issue.
tottacrolla wrote:Could be that the TPS is not switching the ecu into'idle mode' via the idle switch.
PW@Woodsport wrote:![]()
but i find it hard to believe that is only happening after being on the overrun coming to junctions, although there is maximum vacuum being pulled through the bypass on overrun.
hmmm.
