In total these BC's are 10Kg lighter than the Yellow billies with Tein springs, not bad at all
Here are the shiny bits:
The old Yellow billies are in pretty good condition baring the top mounts, i'm sure these will go to a good home
gnzyza wrote:Good to hear your back up and running![]()
Loving the stands and the dash.All the right info and like the shift lights, rev tracker, all very smart looking.
A better screen would be the only thing but it is a prototype so guessing that will change.
Would this be pnp for aftermarket ecus or the syvec specifically?
JD wrote:Hahaha, I just spotted the V-spec decal
I really like this car.![]()
I want to get hold of a bonnet to do the vent thing and do a rad remount in mine at some point.
C35Rob wrote:Excellent work! Those splitter brackets are really nice..
MikeyB571 wrote:C35Rob wrote:Excellent work! Those splitter brackets are really nice..
Thanks, the splitter brackets were actually really easy to make.I Just used some threaded bar, threaded sleeves at each end and made up a little swivel joint at the ends.
gnzyza wrote:Did those brackets and splitter sort the aero issue you were experiencing?
