rear spoiler..? does it work?
Re: rear spoiler..? does it work?
though I suppose you need a flat / sealed floor too. Worthwhile doing I think. Especially if you could make the bonnet mod look... Not xxxx. I hate to admit it but maybe something like Neil's vented bonnet would work.
- IMOC Moderator
synXero wrote:though I suppose you need a flat / sealed floor too. Worthwhile doing I think. Especially if you could make the bonnet mod look... Not xxxx. I hate to admit it but maybe something like Neil's vented bonnet would work.
I'm not a massive fan of the border bonnet but I can see how it would have an effect, you'd have to cut a hole in the front of the frunk for this to work I think,
I am not too fussed about what it looks like.. i am going for the cut and scoop the bonnet making my own
As for the flat floor the way the mr2 is desgned would be very hard to get a flat floor..
sheppy wrote:that might actually be a good location for a chargecooler pre-rad without the hassle of taking the bumper off etc
It'd be an awful location if it's placed in the flow of hot air coming off the engine radiator!
sheppy wrote:synXero wrote:Sealed frunk floor? So basically air in through nosecone out through frunk lid?
that's how the border bumper/bonnet work together
ONLY when you have the border radiator relocation kit which requires the frunk wall cut as well.
otherwise the bumper and bonnet are just for aesthetics.
- IMOC Moderator
shinny wrote:sheppy wrote:that might actually be a good location for a chargecooler pre-rad without the hassle of taking the bumper off etc
I was actually meaning a hole in the floor of the frunk, most likely with some sort of metal "scoops" under the car to direct air up through the pre-rad, however, it's be a lot of work
- IMOC Moderator
jimGTS wrote:sheppy wrote:synXero wrote:Sealed frunk floor? So basically air in through nosecone out through frunk lid?
Yeah man
jimGTS wrote:
I'm not sure our radiators are at quiet such an extreme angle! but yes, AFAIK they do need to be angled differently to work (obv. with all the cutting involved too)
For those of you who have seen these risers people are fitting to the rev5 blade... CFD says it's a waste of time! Makes you wonder whether the TRD wing is actually better or worse for the car, aerodynamically?
Outlaw wrote:MR2 with raised stock rear wing. Drag force 255 N. Lift force 95 N. No influence on lift force, but increased drag!
Pressure
shinny wrote:jimGTS wrote:Image Replaced With URL For Quote http://www.rhdjapan.com/media/catalog/p ... humb_2.jpg
yeh its definitely not, ha.
having recently changed my rad and looking at the area.
aside from blocking the floor, there would have to be some sort of custom slope sheet before the firewall otherwise the air wont get easily directed up and out.
pretty much something identical to what the photo shows as the rads "previous" location.
to be honest, without going into the chassis behind the bumper, or making the rad alot shorter, i cant see how you would be able to tilt the rad forward much if at all! theres only a couple of inchs of room to tilt it forward!
unless of course you custom made some lower supports for the rad further towards the center of the car to allow more tilt at the top before hitting the chassis.
Yeah man
Surely this needs some sort of scoop inside the bonnet to force the air up..
- IMOC Moderator
pistol pete wrote:Surely this needs some sort of scoop inside the bonnet to force the air up..
sheppy wrote:most likely with some sort of metal "scoops" under the car to direct air up through the pre-rad
Yeah man, did everyone paint their eyes on this morning??
sheppy wrote:they also look hideous
Agreed!
I think they came out of Australia, where owners apparently put them on for track days! I'm pretty unconvinced...
sheppy wrote:pistol pete wrote:Surely this needs some sort of scoop inside the bonnet to force the air up..
Doh.. Yeah earlies does that to me
shinny wrote:You know, a guy did some CFD analysis on the SW20 body: http://www.mr2oc.com/showthread.php?t=410768&page=6
...Cool stuff...
Awesome post. Very interesting.
shinny wrote:For those of you who have seen these risers people are fitting to the rev5 blade... CFD says it's a waste of time! Makes you wonder whether the TRD wing is actually better or worse for the car, aerodynamically?
If you look at this plot:
If you can get a wing into the faster moving air at roof height, maybe ?
Is this what you would call a big gay wing ?
Everyone will soon want a BGW
It shows that Toyota did do things for a reason, not just make the car look better.
