JD wrote:What work did you actually have done?Did Xxxx take any detailed photos while carrying out the work?
bobhatton wrote:QUOC2008 wrote:sheppy wrote:
there would need to be air in the system to have air bubbles, there shouldn't any air at all![]()
I dont know but pwr recommend the same as what shaid said
Your charge coolershould never be the highest point as that is where air will collect.
Where is the pump and what way does it pump?
Your highest point should some sort of swirl pot with your fill point and pressure cap.
I agree but i want my boot so where else would u put it
This is the normal way and place to fit a charge cooler without having to turn the turbo round the wrong way
[url]http://i155.photobucket.com/albums/s311/Hattoni/3041bea6.jpg
[/URL]
QUOC2008 wrote:On their website its says 625bhp
Peter Gidden - SBITS wrote:QUOC2008 wrote:On their website its says 625bhp
This one:
http://www.chargecooler.co.uk/index.php ... cfafa1bd8a
£750?
[/URL]
Yes but how much bhp and lag would you get doing it that way..
mine pwr is good for 600+
[/URL]
If you cooler is good for 600 bhp, my one will be good for1500 bhp as it has 4 times the area for cooling than your small one.
There is no lag at all full boost off the line in hill climbs and sprints.
You will never find a turbo that will give 600 bhp and no lag, the two do not go together.
ashley wrote:Honest question for you..
Why do you think this:
Will be laggier than this:
Looking at the two I'd say you've got a longer inlet tract between the turbo and TB now by swapping the turbo around..
.curious?
Oh- and where did your thread in the Member's section go? Keen to see pictures of the finished engine bay, I'm guessing the picture above was before it was complete judging by the lack of cc water pipes and general wiring?
