I was thinking how to prove it- I think you'd need to set up a test rig with compressed air flowing through a tube, with a water injection nozzle in the tube, and some means of removing the water droplets from the air after the nozzle.
If water vapourisation does indeed produce an inter-cooling effect then you should see a temperature drop between the first and last thermocouples.
But.
