joemacmr2 wrote:at idle the revs drop to around 300 rpm and car stalls unless u give it some gas..
Had a Rev1 Turbo in the workshop doing exact same thing.
Turned out to be a leaking HKS dump valve.
joemacmr2 wrote:Was fault intermittent?
I have the oem recirculating valve. How would I test if it's leaking.
joemacmr2 wrote:My mechanic thinks its a fault within ecu.
joemacmr2 wrote:As idle was low I started moving the tps about
joemacmr2 wrote:Is it normal for idle to rise up to normal after pulling plug to icv?
