Lunarmatic wrote:Thanks for the info.![]()
I have a couple of questions about the Konis
- I noticed that someone has the Konis only on the front.
Do you need adjustable Konis on all four corners?
And what does the adjustment give you
- would it be something that you'd be tweaking often?
I noticed that the other dampers that Fensport sell are half the price of the adjustables so I wondered if I would get the most out of the Konis?
I'm planning to use my SC every day rather than as a trackday car.
Cheers.
Yes you have to get the same dampers on all four corners whether they are adjustable or not.
Just because the Konis are adjustable it doesn't mean you have to continually adjust them, more that you have a better chance of acheiving the ride/handling compromise that you want to acheive.
KYBs though half the price, work well enough but are pretty stiff.
Personally i think you'll get a much better ride with teh konis than the KYBs.
That said KYBs are a good budget choice.
choice is yours.
