Earlier ones had 15's all round.
elbon50 wrote:Marf wrote:Just put AD08s on my Mk2
Awesome tyre
Sharp turn in, amazing grip, great feedback.
I'm getting very intersted in AD08s Marf![]()
Limeymk1 wrote:I think the later spec ones are staggered sizes.6j front 7j rear if I recall correctly.
Quigonjay wrote:ad08's are on list 1a?
how did they manage that?
well done yokahama![]()
Quigonjay wrote:elbon50 wrote:Quigonjay wrote:ad08's are on list 1a?
Yes, definately 1a
That surprises you then Jay?
it does surprise me slightly, given that they are usually marketed as atrackday tyre, besides, from what i can remember the old ad07's where on list 1b? could be wrong though
SuperRedMR2 wrote:elbon50 wrote:SuperRedMR2 wrote:I couldn't find S-Drives in 195/50 when I was looking
The wheels I'm currently using have 185/55/15s front& 205/50/15s rear Alex
I ditched that setup within 2 weeks of buying my mk3 alloys- it tramlined really badly to the point where I felt unsafe.
I ditched them within a day of fitting MK3 wheels, horrible to drive! and didn't feel safe.
I went to 195 x 50 x 15 Goodyear F1's all round, they have been absolutely superb for road use, wet or dry the grip is amazing.![]()
They even survived about half an hour of getting hammered round Curborough with no ill effects
( I was there for a magazine photoshoot)
The early MK3(pre facelift, up to around 2003/4) wheels were 15 x 6 front and 15 x 6.5 rear.
The easy way to tell the fronts from the rears is to look at the inside mounting face of the wheel, if there's a 10mm tapped hole between the mounting holes then it's a rear wheel(the rear wheels had a location pin on the inside of the wheel to stop you fitting the rears on the front on a MK3, it just unscrews)
Later ones were 15 x 6 front and16 x 6.5 rear
elbon50 wrote:
IIRC Lauren said she'd used 07s& found them a really
"stonking" tyre
Peter
"stonking" tyre
Peter
I used a Yoko Advan Neova LTS(Lotus).
Basically Elise S1 fronts all round.
They were absolutely amazing wet or dry.
You can no longer get them because Lotus
(they really are up their own ass at times) didn't like it that they were being fitted to non Elises.
Crying shame, because I'd have them again like a shot.Not cheap at over
£100 a tyre but the best thing since sliced bread was the general consensus amongst the trackday elite.
Parada's are a budget tyre really.Have heard they are alright but may suffer from soft-ish sidewalls.
I note that Jimi recommended GSD3's.A good road tyre but to be avoided at all costs if you are going near a track as the sidewalls are made of jelly and due to the huge size of the tread they overheat very quickly.
I've seen GSD3's delaminate.
Not good.
Generally they go all squidgy within a couple of laps IME.
They are not bad in the wet though.
S-Drives aren't bad, have had them when they came out, like it that they are nice and stiff on the sidewalls, so it helps the front end feel more responsive.![]()
T1-R's seem to be a popular forum choice, doubtless because they are cheap.They lack bite though and feel sloppy.
I admit they replaced the legendary RE010's I had on my DC2 and just made the whole car feel absolute rubbish as soon as you tried to push on.
My choice:
S-Drives if you're tight.![]()
AD08's if you've got the dosh.![]()
Lauren wrote:
I note that Jimi recommended GSD3's.![]()
jimi wrote:they have been absolutely superb
for road use
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming'stop raping me'
SuperRedMR2 wrote:If I decided to change all my tyres from 50 profile to 45, what sort of difference is there going to be?
