5th Official SW20 Big Brake Adapter Kit Group Buy
Re: 5th Official SW20 Big Brake Adapter Kit Group Buy
I still need one complete set.
Do you have a local MR2 club that might be interested in the Group Buy?
No mr2 club but we can post up on the swedish toyota board and see if there are some interested people.
Ok, give that a go and we'll see if we can get this GB off the ground again.
I'm still hoping for a complete set too...
Ok thats 3 names then at least. So a few more and we should be able to get this moving again.
Ive posted on the swedish toyota board doesnt seem to be to much interest (not many mr2s in sweden either).. but ill give it a few days and see if someone notice it
So I got one more hooked up on this, I assume we are 4 now then... 1 more to go! come on
Cyrix
madmister2
NoddE
NoddEs friend
Cyrix
madmister2
NoddE
NoddEs friend
Good man. 1 more required.
I've still got that rear set I can send back to you as well Ant.
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
Hi cantfindausername! I don't know if you remember but we talked about this kit a while back, i am still interested, but i have a doubt which i don't actually remember asking
Can i fit bigger caliper using this kit?
Thanks.
Thanks.
Cheers Steve. Keep hold of them for now, and then if/when this gets off the ground I'll have them back off you.
@Warlord - I'm aware of someone fitting Lexus IS 200 calipers to them which use the same carriers as the MR2 caliper, but do require some extra machining. These brackets are designed specifically for the MR2 caliper only.
Heard nothing anymore from that 'franksmits' ?
Nope nothing more.
Hmmm... That will be a problem, was thinking about installing bigger brakes but still haven't looked into it...
I know it's a bit off topic but any idea if the brakes from a JZA80 turbo Supra are any good on an SW20?
- IMOC Committee
Warlord wrote:Hmmm... That will be a problem, was thinking about installing bigger brakes but still haven't looked into it...
Short answer is no.
Clear enough!
The supra 4pots have been done before, but as with any change to the front caliper only, you're going to upset the brake bias and hyraulic system.
