As to whether your issue is just feedback from the road.
Hope you get to the bottom of it mate.
HighwayStar wrote:A steering vibration is such a tricky business since so many possibilities exist for its cause.I took my own advice on Thurs and popped to Oddshoes who has kindly lent me his stock wheels for a bit.
This has massively reduced my vibration problem to the point where it only occurs on certain surfaces and then very much less harshly then before as well.
Maybe with a bigger steering wheel
(I've a 330mm) it'll go all together.
What it has pointed out though is that I have brake judder from high speeds.
perhaps warped discs from whatever caused the vibration before.
Ah well and least it's a different problem, I like a bit of variety me.
As to whether your issue is just feedback from the road..
we all want intuitive, communicative steering don't we.
My steering
'feel' varies on surface but if with a continuous surface you get the vibration at the same speed and it's consistently there then there is an issue to sort.
Hope you get to the bottom of it mate..
and still recommend you try a set of known trouble free standard wheels again.
and maybe a standard steering wheel as well.
