F 800 EAM - any update/news?
Re: F 800 EAM - any update/news?
Have there been any descisions or progress made with this project yet?
Re: f800 eam
bwrc wrote:the amount of development that went into the chassis would more than justify the expense.
What chassis modification/development has been done to this car please
Peter
Its lightweight Peter
Alex
Alex
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming'stop raping me'
pk_090 wrote:Its lightweight Peter![]()
Alex
Yes, possibly so Alex
I'm interested in the details of what improvements have been made
- Lauren
- IMOC Committee
Try doing a search for the car.
It's had loads of work done.
2020 GR Yaris
- Circuit Pack
There's quite a bit on the cars original build/history here:
http://web.mac.com/dghawkes/F800_EAM/Welcome.html
Not all of the information is entirely accurate with regard to the cars current condition but it's not far off.
Since we got it I've not done a great deal to it.
My focus is on getting it running again for the time being
(not sure how I'm going to test it as I can't afford to tax and insure 2 track cars!) although I've also got a few jobs to do on the orange car after our last TSS outing
(and as the current competition car keeping that running is the priority)
So far I've got the turbo/manifold and various bits of pipework off and attached to a slave engine in the garage so I can work out all the plumbing without having to lay on my back.
With regard to the previous conversion I've got a couple of things I'm planning to change:
1) Oil drain at the turbo end needed redoing as the new turbo has a different fitting, not entirely happy with the angle of the drain that was on there anyway so I'll probably redo the whole thing.
Current plan is a straight hard pipe direct from the turbo to the sump which will be at an angle of somewhere around 30 Deg.
2) Oil filter needs relocating to clear the new turbo.
Car came with a Mocal kit for that although I'm going to replace the push fit lines/fittings with AN ones as I don't want there to be any chance of those lines coming off.
3) Oil feed for the turbo was taken from a
'T' in place before the oil pressure sender.
I don't like that arrangement as there is a risk of the T snapping off under vibration etc.
Planning to put the sender back to stock and take an oil feed from the remote filter head.
4) I need to fabricate a bracket to tie the turbo to the bottom of the block as I'm not happy with the weight of the turbo just hanging off the manifold.
5) Once the turbo is in place I need to make up a new downpipe as the flange on the turbo is different and the old one has been cut up.
On top of the turbo I've also identified a few other areas that need attention:
1) Couple of areas of corrosion which have been allowed to get a little scabby
2) Drivers seat installation needs redoing, it's way to hight at the moment, even without a helmet my head is inside the cage and almost against the roof.
In our orange car I've got a good few inches above me even with a lid on.
3) General tidy up of wiring/plumbing in the engine bay in order to ensure that I know what everything is for, that everything redundant is out of the way and that it'll be reliable.
Given that there's very little in the engine bay that's standard in this regard it's important that I've got my head around it all.
Hmmm, it had no alternator until Rickster bunged one on last year
So may have been severely stripped back
No jenny wouldn't meet competiton regs for a modified road car
It also had Hi-Spec Racing front brakes, now removed
& sold on
elbon50 wrote:Hmmm, it had no alternator until Rickster bunged one on last year
So may have been severely stripped back![]()
It also had Hi-Spec Racing front brakes, now removed& sold on
EDIT
OOops just seen your input above Kaiowas
Thanks for that
I want to know what happened to all the moulds.
That's the last I saw of them:
http://www.twobrutal.co.uk/forum/showth ... ody-moulds
I'd be quite interested to know where they ended up too in case I ever need anything!
I think
£700 is asking alot also.
Dont get me wrong you could make that money back no problems but its rather custom kit if you ask me.
Alex
Alex
Would be nice to find out who has those moulds though
may well be possible
Why don't you just make your own moulds?
Whoever made those did it through trial and error so its not impossible for someone else to make them.
A lot of them would be quite complex, and with
Some I would rather take a used mould of something complex yet expensive to buy than to waste slot of cash trying to get the mould I make 100%, and also risk ruining the part you are moulding.
Alex
Alex
SuperRedMR2 wrote:Why don't you just make your own moulds?
IIUC the moulds were made professionally at very great cost Alex
The shape of some differs considerably from stock
elbon50 wrote:SuperRedMR2 wrote:Why don't you just make your own moulds?
So
SuperRedMR2 wrote:elbon50 wrote:SuperRedMR2 wrote:Why don't you just make your own moulds?
So£700 was a bargain really.
Yes it may have been a real bargain Alex
Reading the blurb, one company wanted
Is that guy stoned?! I know they are rare but my god.
.i could make them at half that price easy.
Alex
Alex
And 1 month to make an deliver.
.Crazy.
