Conversion n/a to turbo
Rogue
Re: Conversion n/a to turbo
Post by Rogue »
sheppy wrote:the loom is all taped up etc, with what looks like NO connectors until it get into the frunk, we may just have to swap the whole thing over as this is looking like the easiest option at the moment :shock:
There has to be - the union in the passenger footwell also caters for the loom behind the dashboard...
toxo
Post by toxo »
This diagram is in the BGB for american cars. However the engine loom connects in the same place.
Patrick - Did you mean IE1-4 rather than ID1-4? Or is the nomenclature different between regions.
IG1 is encased in black plastic with 2 nuts underneath it and is the battery live IIRC. IF1 and IF2 are the door loom connections.
Rogue
Post by Rogue »
toxo wrote:Patrick - Did you mean IE1-4 rather than ID1-4? Or is the nomenclature different between regions.
Nope - ID1-4 plug into IE1-4...! :thumleft:
toxo
Post by toxo »
Gotcha :D
Dale_V
Post by Dale_V »
Rogue wrote:
Contrary to what most people will have you believe, unless you start off with a loom from the same revision, and the same market (ie jap loom in jap car) then you will have some changes to make in the footwell. Pay particular attention to the connections for the speedo and ECU-IG circuit if swapping between Jap and UK.
not strictly true , I converted my UK rev2 na to a rev3 turbo and I kept the UK chassis loom and just plugged the turbo engine loom into it at the fuse box
I didnt have to make ANY wiring changes, only thing I had to do was take the oil level light bulb out of the dash. everything works perfect
Ryan S
Post by Ryan S »
cheers again for the advice lads, i'll keep you posted on progress, the car is going to be on the road for the highland drive in march(could be april) with the mr2oc guys :thumleft:
