Kongaroo wrote:Race Idiot wrote:When did you start using winter tyres and when did you take em off. I've been thinking about getting a set but then i'm not sure what i'd do with my lightly used GSD3's on my winter wheels. I'm just hoping it doesnt snow or if it does i'll work at home or something.
I was realy interested in the GT28 untill I heard people having creep issues with them. I thought the EWGT solved the problem in most cases, what make is your kit?
Luckily I have a few sets of alloys so I don't need to go to the tyre shop each time I want to swap on the winter set. I normally do the swap once the weather forecast shows the day temperature to be consistently below 7 degrees and take them off when it starts to be consistently above 7 degrees C. I'll probably be looking to make my swap within the next few weeks.
Yes boost creep is an issue with the GT28RS - more so if you have a very free flowing setup. I was hoping the external wastegate would make this less of an issue but I get a minimum of 18.x psi boost in 3rd gear and the same setting can give me as high as 20.x psi in 4th on a cold day. As you can imagine this makes it a nightmare for setting boost levels and makes mapping the car less precise compared to when I was mapping my TD06. It also means I have a 'minimum' power level that I can't go below even if I wanted to
Peter (SBITs) did all the work of putting the kit together for me so I guess that makes this the first SBITs turbo kit?
I've got a second set of wheels but I realy dont want to run SSR professors in the winter. My buddyclubs are my winter wheels now but they have relatively new GSD3's on em. Where do you get your winter tyres? I can only find them on camskill and it looks like toyo Snowproxies S952 are the only option for 16's. what tyres are you running?
