Car failed MOT on emissions - Rev3 Turbo
Re: Car failed MOT on emissions - Rev3 Turbo
Quick question, L reg import rev 3 turbo doesnt need a CAT does it? Doesnt matter if it fails emissions right?
Watashi wa Ant desu, BAKA!!!
Antstarr wrote:Quick question, L reg import rev 3 turbo doesnt need a CAT does it? Doesnt matter if it fails emissions right?
If the MOT tester knows what they are doing, then it should only be tested on the higher non cat emissions. So it shouldnt fail, but should be put on the correct test.
holdthefone wrote:Mine failed MOT but the garage put some fuel additive in and it passed!
this is interesting - the petrol in my tank is 2 years old I put a fivers worth in from a can, but I would say its half 2 year old fuel, half new fuel. would this make a difference to the emissions?
I was thinking about taking it for a brisk spin (the turbo hasn't spooled on the car for 2 years - it was taken to teh test centre on the back of a recovery truck) Maybe it just needs a good blast
^^^^^^^^^^^^^ try forte advanced gas treatment or forte specialist injector cleaner really quality product does what it says on the bottle
jon wrote:The part number is 89422-35010, it's quite a common part used on lots of Toyota's from '93 to '99.
Lucas Electrical make an equivalent part, SNB842. I've ordered one for a '94 Corolla which was showing the Error 22 and struggling to idle from cold start. I actually measured the sensor today with a multimeter, it was completely open circuit.
Total cost was £10.71, from http://www.simpsonsupplies.co.uk/ Hopefully the Lucas part will do the job at a quarter of the price of Toyota part
Cheers,
Jon
Just noticed your post.
I have checked Camskill and their part number is different to yours.
http://www.camskill.co.uk/products.php? ... s607p30921
I would be interested in the Lucas one if it's cheap enough then even if it lasts only a year I can bin it and keep replacing it.
Steve
The part on the Camskill website is a lambda sensor not a water temperature sensor, which is the part number I quoted.stevenb wrote: Just noticed your post.
Cheers,
Jon
I'll get my coat
