Cadde wrote:Yeah is does but not that bad, it really only makes the noise at around 2000 RPM.![]()
What was making that noise on yours?
You won't like the answer
If it sounds anything like this
Cadde wrote:Does anyone have any advise on what the check, Patrick confirmed the noise is from the engine, Ive been checking the oil on a daily basis and have done a engine pressure test all ok.
Have now done about 300 miles, if there was a internal fault would I have not had some symptoms by now?..
.can anyone help, ideally without taking the head off and inspecting the cams?
