He took the car out this morning and immediately it displayed the boost problem.
They went throught the car systematically and checked everything.
![Dancing \:D/](./images/smilies/eusa_dance.gif)
So now they can continue with the rest of the service, and suspension overhaul
mattymr2 wrote:mines started overboosting today.it started with hesitation midway through the revs in 3rd gear.
it then started overboosting to 1.4 bar but i wasnt really getting any power? also the starter motor icon would momentarily flash up on the dash? any help would be appreciated.
si324mr2 wrote:olly it was your airflow meter causing ur car to overboost??
G-force wrote:I've got the exact same problem mate.i put my foot down and it moves very lethargically, i get a fuel cut at 5k revs, its very slow.
really p155ing me off aswell, but im gonna take some info from this and try remove my blitz ebc.
is the ebc, wiring and solenoid easy to remove? any how-tos? im a n00b:s
Gee Man wrote:I had an over boost problem with mine a while back, all be it a rev3 but stock turbo still.![]()
I had an induction kit and full system exhaust and i could not turn the boost down from 1.25 bar as much as i tried.I had a chat with a few people and ended up buying a restrictor for the bottom of the down pipe(takes it from a 3" to 2 1/2"), this basically gives the turbo a bit more back pressure and like magic my problem went away
I was told my system was that free flowing it would over boost.
Might help your situation mate.
viper33 wrote:Gee Man wrote:I had an over boost problem with mine a while back, all be it a rev3 but stock turbo still.![]()
That sounds exactly like the problem I've got.Where did you get your restrictor, and how much did it cost mate??
Steve-O 2007 wrote:viper33 wrote:Gee Man wrote:I had an over boost problem with mine a while back, all be it a rev3 but stock turbo still.![]()
you get it from a banned site that we cant say on here which is silly as it now means I cant help you properly.As much as I want to help a fellow MR2 owner out I cant due to Imoc adding the site name to the swear filter!!!
Anyway I can give you a clue(Hopefully
starts with a T ends in a v
xxxx![]()
Just wanted to see the filter working.
Click this link mate..
http://tinyurl.com/q2674b
viper33 wrote:thanks guys![]()
I also have minus 25psi on the boost gauge at idle, does that confirm the need for the restrictor?
