Turbo,,, reliable? If you've had an engine failure post here.
steve b
Re: Turbo,,, reliable? If you've had an engine failure post here.
Post by steve b »
So now we have :-
Rev 1 = Three bottom end failures, 1 on number 3 piston, 2 unknown
Rev 2 = Two Number 3 piston failures
Rev 3 = Seven failures
including Brys mate who had number 4 go on his rev3
'97 mk1 Mazda Eunos Turbo track car with 260bhp/ton - soon more as Chris Wilsons going to build me an engine over the winter :o) .
Bry
Post by Bry »
rev 3 low comp on cyl 4
same owner for 7 years meticulously maintained, yearly dyno runs showing 270 whp, been running Blitz ecu and 1.2 bar of boost all those years with no prob but now low comp on cyl 4 (110 psi)
Watch out OZ here I come !!
Steve Horrocks
Post by Steve Horrocks »
Rev 3:
Engine 1 - Piston 3 obliterated & rod through block from running lean (had diode mod in it for FCD which rev3's don't like!!)
Engine 2 - Forged engine. Knackered crank, bearings, cams, head, turbo from powder coated rocker cover
Engine 3 - ok so far (touch wood!)
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
steve b
Post by steve b »
Steve Horrocks wrote:Engine 2 - Forged engine. Knackered crank, bearings, cams, head, turbo from powder coated rocker cover
I don't think that one can be allowed :lol: It broke because a load of sand got in the engine =;
FCD problem,... is that it ran lean as you demanded more fuel than the system could provide or it actually bu88ered with what got injected?
I think that could be added to the list as not many people would think a FCD is a big risk or any risk really.
Rev 3 = Eight failures
Blacklightning66
Post by Blacklightning66 »
looks like rev 1 and 2s are tougher.
steve
Post by steve »
rev3 - low compression on no.3 (4bar) doh! - engine didnt enjoy 1.2bar like my last rev3 did - forged rebuild shortly
Bry wrote:rev 3 low comp on cyl 4
not Mel's one aswell?
dawolf
Post by dawolf »
There's still not enough replies to make any judgement yet about which rev is stronger, however there's no doubt that piston no.3 seems to be the weak link in all the engines.
steve b
Post by steve b »
Rev 3 = Nine failures
paul_4xxxx
Post by paul_4xxxx »
isnt rev3 and rev1 equal in faliures?
