Well, I suppose its about that time!
The westy hasnt turned a wheel since last November
(well, until this week.
But more on that later) as Ive been busily beavering away at the long list of jobs needed to bring her back up to scratch.
I say beavering away, Ive actually been busy with such trivialities as work, Christmas, house improvements etc, but Ive managed to disappear off into the garage here and there.
As ever, its not yet finished, but hopefully Ive broken the back of the work needed.
Its almost ready to go sprinting again, at least!
First job
(and the one that took the most time) was to get the chassis and various suspension components back up to scratch.
Its all 27 years old now and the original paint isnt up to much, so my habit of driving it in winter lead to some pretty crusty looking surface rust:
The rear end was definitely going to need some attention
the wishbones were particularly grotty and the diff was also making some unpleasant noises, so apart it all came
I also discovered at this point that the rear ARB was practically seized!
First step, attack it all with the rust proofer:
Then, once dry and left for a few days to cure, attack with a wire brush drill fitment
And break out the POR-15:
Not a professional job, certainly, but it does the trick.
Job number two was to fit a pair of flared side panels I purchased recently.
This purpose was twofold: partly as an aid to cooling, but mostly to give me better access to the sides of the engine so I could find where that xxxxxx oil leak was coming from.
Unfortunately it was pretty soon clear that it was from an earlier car and wouldnt fit without a bit of bodgery, so I turned to plan B.
Break out the Dremel
I can see things!
Old girl was looking a bit sad at this point.
So, time to start putting a few bits on.
I was a bit limited at this point as the diff was off with Tracsport having a rebuild, so I started with a few cosmetics.
Firstly, fitting of a new set of front wings
(after I botched the existing ones trying to get
them so sit straight) and the Flared Side Panels 2.0:
And then I got a shiny thing back!
Ive finally also been able to confirm that it does indeed have a Quaife ATB diff.
It was a proper xxxxxx to refit though, but after much swearing
It took a bit of fettling to get everything lined up and the speed sensor working again, but we got there.
Final touches were to get the wings a slightly better colour, and give it a good service:
(no pics of the servicing, but you all know what oil looks like? All over the garage floor? Yeah, that.
) I found out where the oil leak was coming from though
turns out a few of the sump bolts werent torqued correctly so some oil was seeping through and dripping off the bottom of the sump.
Finally, new drivers harness:
Put it all back together
Out of the garage
(leaving behind a bit of mess!)
Et voila!
It had a lovely run out last weekend.
Loads of fun! A few little niggles here and there, but nothing major.
All I need to do now is a couple of fiddle bits
replace the choke cable, refit the rear ARB
and give it a run on its new rubber:
First sprint is a week on Sunday.
Definitely nervous now!
