Here it is: http://www.rqriley.com/suspensn.htm
Well worth a read IMO.
g1swx wrote:Hi all,
I am a new member and am waiting to take delivery of a 1990 Rev 1 GT Turbo T-Bar.
It is fitted with 17" Alloys(rubber size unknown at present)
Having read with interest all the comments/info on wheel/tyre combinations, I would appreciate any advice or comments on if the steering may be a bit heavy for my wife??
She is only a midget at 5 ft.
Chris
read somewhere in this thread that wheels alter the gear ratio, this
"they do not at all", the only bit that alters the gear ratio is the final drive.
These ratio's are set by the number of teeth on the driven an driver gears within the gearbox and not cahngeable by wheels size
Larger overall diameter wheels inc tires over that of stock will slow the power to the floor by maybe 5mph in every 80 or so(grows respectively to size increase)
skinthespin wrote:changing the rolling radius of the driven wheels does affect the gearing as in reality this is the last'gear' in the chain of events between the crank spinning and the power getting to the ground.
skinthespin wrote:I dont think you really have a grasp of whats going on, if you increase the rolling radius of the driven wheels tractive effort will be reduced for a given road speed, tractive effort is acceleration/resistance(both rolling and aerodynamic).
It will however increase the roadspeed for a given engine speed, so in theory you will have a higher top speed assuming you can give the driven wheels enough tractive effort to overcome the resistances, so, if your car thumps into the rev limiter in top with ease the chances are by increasing the driven wheels diameter(which has exactly the same effect as increasing the final drive or gear ratio) the vehicle will have a higher top speed.
Unfortunately you are very wrong matey, I can see the angle that you are coming from and why you're thinking it but its incorrect for the situation.![]()
The"last gear" is actually called the final gear, I can give you a picture of one or a annotated transmission diagram should you require it.
You are right that the circumfernce of the wheel does donote speed of rotation to the ground but still it does not'change' the actual gear ratio as all has been dictated prior to this point hence most manufactures use a hub dyno to find more acurate power of a vehicle as do many top performance tunners due to the ability of dialling out slight changes is rotations given by different size wheels.
I think you're trying to make newtons law of motion sound more difficult than it is matey
baz8755 wrote:Does anyone know what size tyres should be fitted as standard on a SW20 turbo revision 4 15" wheels.
The reason I asked is that my beloved rev 2 turbo was written off a few months ago.The car handled beautifully as was completely standard.
I used to be able to drift it around bends and roundabouts and it always felt predictable.
However I now have a standard rev 4 turbo but the front end does not feel as well planted when I try and get the back end to break away.I do not know what size tyres my rev 2 had except that I was using F1s.
However my rev 4 has front 205/50 and rear 225/50 15".
What can I do to get the front feeling as it should.
Also the wheels on this car are the anniversary diamond cut ones and are severly corrided, can these be refinished?
Baz
quigonjay wrote:have you had the geometry set up?
a bit of negative camber can help turn in/reduce understeer as can a front strut brace
its just the rev1's that had the oversteer trait with rev2+ having the built in'understeer'
skinthespin wrote:I have since backed off on the camber on the front(by adding more negative, the wheels were virtually upright before)
