Gazza_DJ wrote:The full rebuild kits cost a fair bit more than that to do it right.
You need-
1x http://www.ebay.co.uk/itm/Toyota-MR2-SW ... 1654254659
1x http://www.ebay.co.uk/itm/Toyota-MR2-SW ... 2128897985
1x http://www.ebay.co.uk/itm/Toyota-MR2-SW ... 1958725150
2x http://www.ebay.co.uk/itm/Toyota-MR2-SW ... 1369777214
The rear kit that comes with the piston is an empty piston with no handbrake mechanism- it is possible to transfer them, but it's long, fiddly, and time consuming.
This saves a lot of time
/ aggro.
There may be nothing wrong with your existing pistons, if you're going to reuse check them very carefully.
Any pitting they should be replaced as the pits will just collect crap and accelerate corrosion, shortening the lifespan.
Probably wise to replace the bleed nipples as well while you're at it.
£341 for 4 fully rebuilt calipers is a good deal.
Assuming that's calipers only
(no carriers), then all you need to do is replace your slider bolts on your existing carriers.
Draven wrote:Hmmm..
Yes i like it.Not sure i'd do it myself though.
Draven wrote:Well I hope they stay stuck,
Nice work![]()
JLW wrote:Draven wrote:Well I hope they stay stuck,
Nice work![]()
Well, you jinxed it.
I'll be asking for a refund
Nearly all of them are peeling off and it's not even been driven!
JLW wrote:
E N G I N E:
Phoenix Power side mounted intercooler
Berk technologies De-Cat pipe
Blitz Nur Spec R full exhaust system
Greddy Type R Adjustable BOV
/ dump valve
8MM Magnecor Ignition Lead Kit
TRD Sports Iridium Sparkplugs
- Grade 7
Apex Power Intake
TOM's radiator cap
TRD oil cap
BRD gearbox linkage bushes
Bosch
"supreme power" battery
SAMCO boost pipe hoses
Ceramic coated intercooler pipes
C H A S S I S:
Meister R zeta R CRD+ coilovers
( 3 way adjustable
TOMS Front Strut Brace
TOMS Rear Strut Brace
New drop links
& bushings all round
Eibach Camber Bolts
- Front
Full archwork roll by Arch Enemy
B R A K E S:
New Rev 3 Turbo callipers all round
Porterfield RS4 pads
MTec dimpled
& grooved discs with black coating
Gulf RF1000 high performance brake fluid
HEL braided lines all round
( yellow
W H E E L S& T Y R E S:
Front
- Rota Torque's 17x8J et35
Rear
- Rota Torque Drifts 17x9J et30
( 5mm spacers
Front
- Yokohama AD08r 215/40/17
Rear
- Yokohama AD08r 235/40/17
E X T E R I O R:
Full re-spray by DPM autobody in OEM
"smg"
Border carbon bonnet
Aerocatch Plus flush lock kit
Aeroware polyurathane front lip
Smoothed front bumper
Greddy Gracer side skirts
Crystal Raybrig
( style
) Headlights
Smoothed GT spec electronically retractable mirrors
Phoenix Power rear spats
TRD wing
, with carbon end caps
Rev 5 clear front light units
Raybrig
( style
) Crystal headlight units
UK spec front indicator delete mouldings
Full 70% dark window tint by Auto Eclipse
Osram nightbreaker 7000 headlight bulbs
Osram Nightbreaker H3c fog light bulbs
I N T E R I O R:
OMP corsica 330mm deep dish wheel
/ yellow stitch
MoMo boss wheel adapter
Corbeau Pro series XL in leather with yellow top stitch x2
Corbeau Side mounts x2
Rouge Motorsport ground rails
Corbeau lumbar support
( drivers seat
TRD duration gear knob
Sickspeed suede
/ yellow stitch gear surround
Gloss black dash plastics
JDM Toyota rescueman 3 security hammer
JDM OEM toyota footwell flare
Black rev 1 T-Bar headlining
+ tims and shades
UK Rev 5 Leather Door cards
Modified AC unit with Blue bulbs and backlight
Peter G
@ SBITS
Modified clock
( blue overlay
White 501 LED bulbs in dash
A U D I O:
Edge 6.5 Front Speakers
Edge 4 Rear Speakers
Sony MEX
- BT4000U Bluetooth Head unit
S E C U R I T Y
Clifford Alarm System 3
S E R V I C E& O I L' S:
Redline Mt90 gearbox oil
Fuchs Titan Pro Race R 10w50
OEM Toyota oil filter
OEM Toyota fuel filter
