I read somewhere, don't know how true.
But it also helps clean the internals, essentially a steam clean everytime it's used.
Helping to remove deposits and evening out compression in each cylinder
(basically helping and removing battle carbon build up on the pistons).
Many people are banging on about whether it cools the intake temps or not, but surely more important is whether it helps keep detonation at bay.
Many moons ago, on my rev5, tuning on the dyno, we switched Wi on and off.
Although Ryan
(2bar tuning) didn't mention any change in intake temps, he did note reduced knock/det situations.
Same boost/timing! Simply on and off test.
Only for a pull or 2 to be fair.
So what about swinging this arguement around and consider it's reduced det possibilities, if you don't agree/believe/know it drops temps at least.
I have to say, on my power fc on my old car, intake temp reading on the commander, i don't remember any sort of decrease in intake temps.
It certainly was not significant otherwise I would have remembered in sure.
I run wi today to help keep det at bay and to clean the engine, if I see lower temps, great, if not, not an issue.
So in saying that.
I imagine a cc setup running wi would be quite bullet proof if tuned well.
