[Mk2] [Turbo] Rebuild - 500 HP CANDY RED MR2
Re: [Mk2] [Turbo] Rebuild - 500 HP CANDY RED MR2
I must admit, even before I saw the comments, I was shocked to see a cheapo ebay exhaust on this extensive, meticulous build!
ashley wrote:What is the oilcatcher in the front for?
EDIT- that's the water tank isnt it
It is the water tank for the water cooling
![Image](http://img.tapatalk.com/d/14/03/25/7edezese.jpg)
Neue Sonnenschein Batterie verbaut, dazu goldene Anschlussklemmen und einen neuen Batteriehalter aus Alu gebaut welcher poliert wurde.
.![](./images/smilies/spacer.gif)
![Image](http://img.tapatalk.com/d/14/04/15/esutegap.jpg)
![Image](http://img.tapatalk.com/d/14/04/15/upuheqah.jpg)
Probemontage der Wasserkühlanlage.
![Image](http://img.tapatalk.com/d/14/04/15/ada2yses.jpg)
sw22 wrote:New sunshine was installed battery, built to golden terminals and a new battery holder from aluminum which polished.
This is just getting weird now
![Think :-k](./images/smilies/eusa_think.gif)
sw22 wrote:RyanRs wrote:This is pretty amazing! i would be scared to drive this after its all done, just washing the body after a drive would not be enough!
You have beaten me to the rear brake conversion idea too..
What spot caliper are you using? any chance of a look at your adapter bracket??
What thickness steel did you use for this?
10mm
You can order the adapter here:
http://www.k-sport-germany.com/
Thermofühler in den Wasserkreislauf des Motors eingebaut, direkt hinter dem Thermostat
![Image](http://img.tapatalk.com/d/14/04/22/uda5y6u9.jpg)
Neue Hupen von Hella eingebaut
- 118 db
![Image](http://img.tapatalk.com/d/14/04/25/a9ydeze8.jpg)
Danke.
Und wenn sich jemand wundert, warum der andere Kühler wieder draussen ist.
Die Verrohrung passt nicht so wie ich mir das vorstelle.
die bögen kommen vorne zu weit raus.
somit kollidiert das ganze mit der Stoßstange.
Hier der alte Einbau:
![Image](http://img.tapatalk.com/d/14/02/21/etany9yn.jpg)
Also nochmals raus und nach England geschickt.
dort lasse ich mir die Ausgänge des Kühlers umbauen und eine Druckprüfung durchführen.
Hier die roten Anschlüsse sind die alten und die blauen müssen neu gemacht werden.
Hab dazu mal eine Skizze gezeichnet:
![Image](http://www.tomchemie-forum.de/albums/userpics/10001/normal_K%C3%BChler.jpg)
wichtig ist, dass man hier auf den richtigen Winkel achtet:
![Image](http://www.tomchemie-forum.de/albums/userpics/10001/normal_K%C3%BChler-2.jpg)
auch ist der MR2 nicht ganz symmetrisch gebaut, d.h.
links muss das rohr weiter raus als rechts.
![Image](http://www.tomchemie-forum.de/albums/userpics/10001/normal_K%C3%BChler-3.jpg)
so sollte dann der fertige Kühler aussehen.
![Image](http://www.tomchemie-forum.de/albums/userpics/10001/K%C3%BChler-4.jpg)
That looks much better
Blende nochmals um zwei Anzeigen erweitert:
![Image](http://img.tapatalk.com/d/14/05/01/4age6ybu.jpg)
![Image](http://img.tapatalk.com/d/14/05/01/u9u5amab.jpg)
Front angebaut aber noch nicht eingestellt:
![Image](http://img.tapatalk.com/d/14/05/01/ja6ahyry.jpg)
![Image](http://img.tapatalk.com/d/14/05/01/a3u4e3yr.jpg)
![Image](http://img.tapatalk.com/d/14/05/01/enumypar.jpg)
![Image](http://img.tapatalk.com/d/14/05/01/4u6y5yhe.jpg)
Adapterplatte des k-sport fahrwerks verbaut:
![Image](http://img.tapatalk.com/d/14/05/01/ypaqy6yq.jpg)
Heckflügel montiert und probehalber rangehoben
![Image](http://img.tapatalk.com/d/14/05/01/aqanarad.jpg)
![Image](http://img.tapatalk.com/d/14/05/01/quzy7aba.jpg)
Neue Targadachdichtungen eingebaut.
hier mal das Innenleben eines Targadaches:
![Image](http://img.tapatalk.com/d/14/05/01/aganusum.jpg)
Fahrwerk einstellen
![Image](http://img.tapatalk.com/d/14/05/02/e7ehyta7.jpg)
![Image](http://img.tapatalk.com/d/14/05/02/apunu3yv.jpg)
![Image](http://img.tapatalk.com/d/14/05/02/hujesazu.jpg)
![Image](http://img.tapatalk.com/d/14/05/02/9eqysyha.jpg)
![Image](http://img.tapatalk.com/d/14/05/02/ebusy3yg.jpg)
![Image](http://img.tapatalk.com/d/14/05/02/6ajenebu.jpg)
![Image](http://img.tapatalk.com/d/14/05/02/tujyga4e.jpg)
Heckleuchten angeschlossen und
Rückfahrlicht mit 2 x 102 leds eingebaut
![Image](http://img.tapatalk.com/d/14/05/05/su5ybaha.jpg)
![Image](http://img.tapatalk.com/d/14/05/05/ume7agu6.jpg)
Neuteile für die Installation der Frontscheibe
- Lüftungsgitter eingetroffen
![Image](http://img.tapatalk.com/d/14/05/12/u6yvy4ys.jpg)
![Image](http://img.tapatalk.com/d/14/05/12/y2yhyze4.jpg)
![Image](http://img.tapatalk.com/d/14/05/12/tumube4y.jpg)
![Image](http://img.tapatalk.com/d/14/05/12/5amarana.jpg)
![Image](http://img.tapatalk.com/d/14/05/12/emaryqa5.jpg)
Wasserladeluftkühler Schläuche verlegen:
![Image](http://img.tapatalk.com/d/14/05/13/4upajupu.jpg)
![Image](http://img.tapatalk.com/d/14/05/13/jupa2uqa.jpg)
Radioblende finish.
![Image](http://img.tapatalk.com/d/14/05/13/hazupynu.jpg)
Radioblende finish.
What have you got planned for the handbrake cable? ![](./images/smilies/spacer.gif)
