So, onto the build.
I only use the best assembly lubes and sealants.
Not cheap, but they're just as important as the component parts.
Dirko-S is not only used by manufacturers and top race teams because it does it's job properly and reliably, but also has a much shorter curing time than most sealants.
![Image](http://www.sbits.net/noble/graphogen.jpg)
The block is two halves, upper and lower.
So first job was to dry-install the crank to check bearing clearances with Plastigage.
So new bearings fitted, block halves torqued together, and clearances checked.
All spot on.
Then take apart, clean off all traces of wax, and refit crank and bearings with new bolts.
![Image](http://www.sbits.net/noble/crank_installed.jpg)
![Image](http://www.sbits.net/noble/block_lower.jpg)
![Image](http://www.sbits.net/noble/block_bolts.jpg)
Crankshaft fitted.
Now onto pistons and rods.
Noble used Arrow Precision rods in all their 3 litre engines, so they were remove from old pistons, cleaned and put to one side for refitting.
One of a handful of sets of pistons custom made by Cosworth.
Compression reduced to 7.9:1.
A cool
£1700.
![Image](http://www.sbits.net/noble/pistons_in_box.jpg)
First job was to spend a couple of hours gapping all the top and 2nd rings.
Done.
Next job was to fit rods to pistons, then rings to pistons.
Done.
First piston was slipped into bore, big end cap nipped up, and cranshaft rotated to check for binding.
DISASTER
- crank won't fully rotate.
