simba90 wrote:Ok, I'll check the leads in a bit.I do have an older set of splitfire leads that i know work so I'll try them as well.
I swapped back to standard toyota ones as the splitfires let water down into the plug wells every time it rained.
Plugs are pregapped so i havent messed with them.I've read that you shouldn't try to gap iridium plugs as the tips are brittle.
very true, they are known
boost leak/dodgy dump valve
