and your reasons why it is,
i have just bought this and something seems wrong
Can someone clarify if this is an N/A or turbo exhaust
Re: Can someone clarify if this is an N/A or turbo exhaust
doesnt all turbo exhausts pass over the rear subframe towards the right?
think im missing like 18" of pipe straight
I believe it's turbo. However the pipe going to the sat appears to be too far to the left. Thought that this ran more central?
Is that it or is there something else?
Apexi Induction, Gutted Cat, Departure Exhaust, Magnecor Leads, St205 cc, Blitz ebc.
Carbotech pads.
Carbotech pads.
Arrrr. It's a N/A exhaust and is missing the decat pipe or the cat.
Carbotech pads.
Carbotech pads.
Extubby wrote:Arrrr. It's a N/A exhaust and is missing the decat pipe or the cat.
Agreed
Pete J wrote:Extubby wrote:Arrrr. It's a N/A exhaust and is missing the decat pipe or the cat.
Agreed
'97 mk1 Mazda Eunos Turbo track car with 260bhp/ton - soon more as Chris Wilsons going to build me an engine over the winter ) .
thanks,
does the n/a exhaust pass over the subframe on the left hand side?
no dont think so just replaced my na exhaust with a single exit n i dont recall it going over the subframe......
Just looked ebay, i see a decat pipe is meant to go inbetween.
dammm.
dammm.
- IMOC Affiliated Company
of course it go's over the subframe.
The flexi sections on the NA's, after it has gone over the subframe are about 3" shorter than the turbo. So you could make it work. Just a little chopping/welding.
is it only the n/a which has a standard pipe/cat inbetween the the exhaust?
i know it could fit, but with modification, some of the flanges are downsized from 3" to 2.5", so that would need changed back to 3".
this stock turbo exhaust looks the same apart from different main pipe?
http://www.imoc.co.uk/forums/viewtopic.php?t=93569
sorry didnt think about the flexi section damn man flu mixed my brain up
I did this for someone a few years back.. Any help?
The important thing is if it has a 'rounded triangle' 3 bolt flange for the downpipe. If it has that you can probably get a De-cat for a NA and make it fit.
that picture is great. seems i have a mish mash of bits
