Thanks.
dawolf wrote:Does anyone know how much work is involved in changing the gearbox oil? My local garage said they think it will cost around£40 all in.
Is that about right?
Thanks.
RedMR² wrote:It cost£45 to fill up my gearbox with Redline MT90
make sure they don't whack mineral oil in there.MT90 all the way!
jimGTS wrote:afaik, it isnt simply, undo plug, drain and refill.
you have to syphon it in..
.afaik
i havent done it myself, but seen a how to somewhere.
dawolf wrote:Hmm, okay.They said they thought it would take about half an hour if there was a drain plug so they must use cheap stuff.
I'm not sure whether to just leave it now as the gearbox is fine as it is.
Just thought it was a good idea to change the oil.
