[Mk2] [Turbo] boot mounted intercooler
prosser
Premium Member
Post by prosser »
how does a boot mount get cold air in ?? thinking of doing one on my car as i dont use it much any help would be great!!!
simmo490
Re: [Mk2] [Turbo] boot mounted intercooler
Post by simmo490 »
from the underside of the car mate, cut a hole in your boot
but needs somewhere to flow, either vent in top of boot or holes in rear panel
Dan88
Post by Dan88 »
yeh ivee seen someone cut a hole in the top of the boot and put a small scooby vent in there, i personally didnt like the look of it, but any sort of vent in the top should help airflow
Razor04
Post by Razor04 »
This is what Phoenix power were doin in the mid 90's:
check out the spal fans :thumleft: [/img]
prosser
Premium Member
Post by prosser »
do you need to put some sort of scope under the intercooler or would it flow that way with just the fans?
Leakie Tbar
Post by Leakie Tbar »
prosser wrote:how does a boot mount get cold air in ?? thinking of doing one on my car as i dont use it much any help would be great!!!
Looking at your garage am I correct in thinking you are still running mainly stock turbo etc,?,
if you are why bother cutting up your boot when a good side mount will outperform the stock turbo set up,
ashley
Post by ashley »
The bootmount in my car pushes air down through the i/c and out of the hole in the boot floor- considering helping the boot breath with some subtle mods (really dont want to use a scoop).
Only issue sucking air from under the car is the exhaust right under the i/c- not an ideal source of cold air!
TBH if I was starting from scratch I'd use a water charge cooler instead...
prosser
Premium Member
Post by prosser »
no im just having my engine rebuilt with forged internals and a bigger turbo i havent changed my profile because i havent done it yet, i already have a hks intercooler but i dont think it is man enough to cope with the 400 bhp i want :thumleft:
prosser
Premium Member
Post by prosser »
just found a good pic of one
cantfindausername
Post by cantfindausername »
This is my set up.
Have 2 x 11" spal pushers on the top and will be making a duct to exhaust the air backwards.
***RIP Car13 ***
*** Now in an Evo ***
skipp123
Post by skipp123 »
that looks a nice bit of kit, what kind of intake temps do you see with that setup>?
cantfindausername
If thats aimed at me, I have no idea. Car hasn't moved for 18 months so could be some time before I get any data. :cry:
***RIP Car13 ***
skipp123
Post by skipp123 »
cantfindausername wrote:If thats aimed at me, I have no idea. Car hasn't moved for 18 months so could be some time before I get any data. :cry:
it was mate yes,
whats up with the car? i know how u feel bud iv only just got mine back running exactly right and mapped done like 500miles at low boost and now the weathers so crap iv decided to just store her till next year..... think iv driven the mr2 about 20times this year ](*,)
cantfindausername
I haven't even seen my car since July 07! :roll: #-o
Nothing up with the car, just me not applying pressure to the tuner. Time for that to change though over the coming weeks.
***RIP Car13 ***
Yas
Post by Yas »
cantfindausername wrote:I haven't even seen my car since July 07! :roll: #-o
Same situ here mate, know how it is when tuners can't be asked ](*,)
When cutting through the boot floor do people add braces or something to strengthen the body or is that not needed?
Low Spec!
RIP TweenieRob
http://www.eshishaonline.com
fastgrant74
Post by fastgrant74 »
I know people generally run these on higher power cars, but I also dont buy the 'sidemount up to 400' rule- on a track day, intake temps get very high, and lower temps are a good thing full stop.
Has anyone done this on a fairly standard turbo setup? I wonder what the difference is in lag?
Steve Horrocks
Post by Steve Horrocks »
I've not yet, but think i will be doing when i pull my finger out & do a bit more. You can tell the difference in floor strength once it's cut out, flexible, etc. but shouldn't be a proble chassis wise as it's fairly solid around there.
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
Steve Horrocks
this is mine:
from underneath:
prosser
Premium Member
Post by prosser »
what about heat from the exhaust is that a issue?
Steve Horrocks
It's having a heat shield put back on, flush with bodywork to front, with tapered gap towards the back of car. Plus 2 Spal fans on top of IC to pushair through.
