hi guys
does or can anyone explain what the t-vis does on my rev 2 tubby, i am in the middle of sorting out numerous problems on my car, as i have been sorting out the oil leaks and other bits i found this t vis thing but not sure what it does? it also has toyota and yamaha writen on it?
i have a rev 2 tubby if this helps.
many thanks
dave
Ps i am new to the Mr2 scene and just
[Mk2] [Turbo] quick question does or can anyone explain what the t-vis does on my rev 2 tubby
Re: [Mk2] [Turbo] quick question does or can anyone explain what the t-vis does on my rev 2 tubby
It regulates boost in 1st and 2nd. Disconnect it to get full boost. Makes a big difference.
it also regulates boost in 3-4-5 if you get a problem its trims the boost back to 6psi make sure your car is in REALLY good condition mechanically before you do as you loose that protection.
- IMOC Committee
It's the T-VSV that regulates boost control, not the T-VIS. T-VIS is a variable intake system present on MK1 and MK2 up to and including Rev 2 which consists of butterfly valves in the inlet manifold. Idea being that it opens up more air intake capacity as the revs rise. If you disconnect it you will permanently restrict your air intake.
The reason it says Toyota and Yamaha all over it is because the 3S-GTE is designed and built for Toyota by Yamaha.
- IMOC Committee
Tiny wrote:sorry ill get my coat
lol... easy mistake to make!
thanks guy's for the info i tried looking everywhere for proper info on it
i have been told to leave it on as it helps keep the power and torque curve sweet as a nut.
thanks dave
thanks dave
toxo wrote:It's the T-VSV that regulates boost control, not the T-VIS. T-VIS is a variable intake system present on MK1 and MK2 up to and including Rev 2 which consists of butterfly valves in the inlet manifold. Idea being that it opens up more air intake capacity as the revs rise. If you disconnect it you will permanently restrict your air intake.
Yes and no.
You disconnect it, it's left perminently open, not shut and restricted.
Some sources say it opens at X rpm, to help torque. some say it opens as soon as you see boost, so really doesn't do much.
I disonnected mine and when mapped was still seeing 290lb on my rev2 with a ct20b. Hardly a disadvantage in my case.
- IMOC Committee
jimGTS wrote:Yes and no.
My bad My only real TVIS experience is on a MK1 as I have a rev3 turbo...
wowowo, hate to revive a thread but does the tvis control that goose honk noise? it happens for me when starting to boost, or when the car is struggling up a hill cos its a fat bloater, and cant move without boost
- IMOC Committee
The goose honk is because you have a recirculating dump valve and have removed the stock airbox and resonator. Completely unrelated!
this is ture.
wheres MY coat!
wheres MY coat!
- IMOC Committee
Like I said up there...
It's what creates the lower boost limit in 1st and 2nd, and controls boost up to whatever the factory limit is in other gears. It also informs the ECU of overboost so the ECU can fuel cut to protect the engine.
Im a bit confused now . According to Fensport who supplied my turbo I'm running at 12psi as regulated by the actuator on the hybrid turbo. Surely though, if my T-VSV is still hooked up then I must be running no more than the factory set 10psi???
Mike wrote:Im a bit confused now . According to Fensport who supplied my turbo I'm running at 12psi as regulated by the actuator on the hybrid turbo. Surely though, if my T-VSV is still hooked up then I must be running no more than the factory set 10psi???
no, if 12 is the actuator pressure on that turbo, id imagine your running 15psi!
12 + 3 for the tvsv...
stock actuator is 7psi.
jimGTS wrote:Mike wrote:Im a bit confused now . According to Fensport who supplied my turbo I'm running at 12psi as regulated by the actuator on the hybrid turbo. Surely though, if my T-VSV is still hooked up then I must be running no more than the factory set 10psi???
It appears my T-VSV is no longer connected, theres only one pipe connected to my actuator so I guess thats how they get around the T-VSV.
toxo wrote:It also informs the ECU of overboost so the ECU can fuel cut to protect the engine.
Rubbish. The TPS (turbo pressure sensor) on the rear firewall does that. It also drives the stock boost gauge.
A VSV is a solenoid, thus does not measure or inform. Sensors do that job.
