After long last I'm ready to put on my phoenix power side mount...Can anyone recommend any companies that will mail order a set of pipes for this intercooler? or is it better to get them custom fitted?
I have the metal shroud, and plan to use the stock spal fan...is there anything else I would need?
Also, how will I get my hks ssqv to fit onto the custom piping?
[Mk2] [Turbo] Intercooler Piping for Phoenix Power SMIC...?
- IMOC Affiliated Company
Re: [Mk2] [Turbo] Intercooler Piping for Phoenix Power SMIC...?
I can custom make them if you like but would require your car + intercooler or just the cooler.
Luke
Luke
think I found my man
has luke disappeared?
still looking for someone to fab these pipes...anyone know someone in the midlands that could do this?
run no bov like mine
one of my PP ic pipe is custom, so can be done....
word of warming, these pipes are larger than greddy ic pipes, as ive seen found out (none of my greddy ic mikalors or hoses fit on my PP ic or pipes!) so measure the hoses you need.
It should be easy to do...its just bent tubes end of the day, but I don't know anyone that can do it
Is it safe to run with no bov??
Any idea what the pipes should be made of? would aluminium do the trick?
i couldnt tell you that info, but am sure luke should be able to help, no idea where hes gone tho.
there's a PP kit FS on the OC at the mo' - it has the normal pipework and uses a BOV. do the PP and Apexi intercoolers share the same core ?
not seen any apexi ICs for sale....is there such a thing?
yep loki (koracing) in the US uses the apexi SMIC core with custom pipes.
and this might be of interest too Jim :
http://www.mr2.com/forums/turbo-3s-gte/ ... o-kit.html
splashnatz wrote:there's a PP kit FS on the OC at the mo' - it has the normal pipework and uses a BOV. do the PP and Apexi intercoolers share the same core ?
bargain price considering it comes with a greddy bov as well!
ill hava look through that when i can.
the strangly, the downpipe looks entirely different to mine...
jimGTS wrote:ill hava look through that when i can.
no external wastegate either
yeh or big ass screamer!
shabz, I just used pipes from Viper Performance (google them) to match up with the bolt on pipe from the bottom that's with it.
http://www.imoc.co.uk/forums/garage.php ... ge_id=7195
With custom pipe for BOV
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
