[Mk2] [Generic] Is there a pollen filter?
The blowers seem a bit weak on my mrk2 (rev 2 t bar tubby) is there a pollen filter some where? Im thinking its blocked if there is, had a search around and couldnt find anything though?
Re: [Mk2] [Generic] Is there a pollen filter?
No I'm pretty sure there isn't a pollen filter. Could there be a blockage where the air gets sucked in from outside?
- Lauren
- IMOC Committee
It could be the resistor pack is gone on the fan. If this is the case you will lose certain fan speeds so it could be that when you put it on say 2 it is still only blowing at speed 1.
If the whole thing messes up you will only get full speed or no speed, but individual coils/resistors can go, I had it happen to mine. So check all speeds work correctly.
2020 GR Yaris - Circuit Pack
sounds the same thing that happens to nissans, but mines not doing that its just seems a bit weak, might have to find where it sucks and see if theres anything there blocking then.
its working fine now, dont think i had the directional button thingys pressed in properly
- Lauren
- IMOC Committee
Nails wrote:its working fine now, dont think i had the directional button thingys pressed in properly
LOL!!
Well glad you got it sorted, if only all problems were solved so easily!
