[Mk2] [Turbo] laggy turbo
boost is crap basically acceleration is not as quick as it was , do I need a new turbo ? . does a compression test check how the turbo performs can a local garage check this aswell ? . any help appreciated thanks
Re: [Mk2] [Turbo] laggy turbo
any error codes?
allan welsh wrote:any error codes?
Agree, first port off call as loads of things could cause the ecu to run in safe mode
I dont think I had any codes , i done the test and all i had was the lamp indictor continually flashing which means its ok isn't it?
lee.w wrote:I dont think I had any codes , i done the test and all i had was the lamp indictor continually flashing which means its ok isn't it?
no, when it flashes then that is the ecu giving you the code
mrtee wrote:lee.w wrote:I dont think I had any codes , i done the test and all i had was the lamp indictor continually flashing which means its ok isn't it?
http://www.mr2-tech.com/bgb/mechanical/ ... stem/4.htm
IIRC it continually flashes meaning theres no codes stored
greeny wrote:IIRC it continually flashes meaning theres no codes stored
what does the symbol look like
the yellow check engine light in the top left corner of the other symbols was continually flashing when I hooked up the terminals.
