Have you suffered from cracked blocks, between 2 and 3?
I've done 2 now.
What have you done about it?
Any help would be great.
Roy
greeny wrote:what size pistons you running royash?
larry93 wrote:Have you tried this Roy?
http://www.twosrus.com/catalog/product_ ... cts_id=297
not sure who has?.
might help
thelegend wrote:why dont you just build your engine from a rev 2 block? i cant remember a case of a rev 2 block failing.
royashmr2 wrote:greeny wrote:what size pistons you running royash?
There HKS ones 87 mm.I know its not ment to be good for them borin the block this much.
but thats the size for the 2.2.
Correct me if i'm wrong.
Andy F wrote:Im guessing Royasmr2 was running 2 bar+??
This is the point where the car really starts to come on song..
.but the weak points will be found pretty soon.
Bad luck fella
Andy F wrote:Hi Michael
Rev1 block and 86.5s
I have made a couple of changes to the car, so will be going for another map session soon, im aiming for 2.3/4 bar this time so who knows i could be in the split block club soon LOL
Group A block is the way forward, and i may have found one
