[Mk2] [Turbo] 850cc fuel injectors
Does anyone know if i will get any gains by puting 850cc injectors on my rev2 with standard ecu?or is it a waste of time?
Re: [Mk2] [Turbo] 850cc fuel injectors
larger inj's will need mapping to work properly. Also the only advantage of having larger inj's is so you can safely flow more air -from increased boost or larger turbo. doing this however will require mapping.
the oem ecu cannot be mapped as it is.
so if i put a boost controler on i will get a beter response than std injectors
daiodavies wrote:so if i put a boost controler on i will get a beter response than std injectors
a boost controller will allow you to adjust the turbo psi and gain to give you more power, you may need a fcd for a rev2, the standard injectors will run higher duty cycles but be quite adequate for the standard rev2 turbo
dont meen to sound stupit but what is an fcd.and what do u meen by quite adequate
daiodavies wrote:dont meen to sound stupit but what is an fcd.and what do u meen by quite adequate
adequate as in they will work to within the turbo's capabilities and a fcd is a device, it's full name is fuel cut defender and it just changes the ecu's safety cut off for boost levels and therefore allow you to run higher boost
aftermarket ecu and mapping will be needed for larger injectors
Chears lads thats more my language thanks for the info
