I have been speaking to Ryan over at 2 Bar Tuning
He advised me that i get them cleaned and flow tested before fitting.
It was
Of the four, 2 had no flow at all
Post cleaning, all four have perfect spray pattern and equal flow.
Hope that helps guys!
^Trickster^ wrote:They injectors should be tested from the factory in my opinion, I would not clean brand new injectors, do you send your brand new short block from toyota off to be dismantled to make sure its within tolerances? No you would trust that it is correct seems tho you just paid through the nose for it.
Each to their own opinion here and I can understand why people do this but I dont buy brand new items and then send them off to have them tested.
Graeme
Harry wrote:Good report back Baz good Idea and tip to flow test the Injectors.After all the fueling Is crtical why leave It to chance.
These
*850 cc* Injectors come highly recommended as they are made by Denso, Japanese company who produce the OEM Toyota's Injectors.
Exactly the same as the Blitz units which are just re-branded bu tat around
£ 100 per Injector.
The lag time and spec as the Sard 850 cc's are Identical btw! One can not beat this value from RHDJAPAN.
Around
£230 to UK door.
http://www.rhdjapan.com/jdm/SARD-850cc- ... -GTE-20984 Hey Baz can not wait to see what my previous CT 20 Hybrid Is going to do with your set up and Ryan's mapping.
It would have been good for suppliers to mention that Injectors come or might be delivered with gunk In them to protect them In transit.
daiodavies wrote:Does anyone know if i will get any gains by puting 850cc injectors on my rev2 with standard ecu
