Morning,
Have had my EVC installed since christmas but only now am i getting round to connecting up the rpm and throttle inputs, but i haev lost the little book with all teh ecu pin diagrams. Can anyone tell lme with pins on teh ecu are which. Ive been searchin fro ages with no luck.
Cheers in advance
[Mk2] [Turbo] HKS EVC V installation problems
Re: [Mk2] [Turbo] HKS EVC V installation problems
OK, so i thouight i had located the correct wires for the RPM & throttle signal, but now im not to sure.
The EVC says im either 100% throttle or 0%. and the RPM is way out. Could someone who has a HKS EVC post a pic of what wires they hav spliced into at teh ECU so i can check mine is rite.
Are you sure it's the EVC V? I have this but it doesn't show throttle/revs as far as I know, only boost/vacuum. I do have the install instructions somewhere but not sure they'll be much use to you
EDIT: Is it this one?
no mate, defo a evc 5, but think i have it sorted now.
Glad to hear you've sorted it. The pic is definitely the EVC V though...
