window motor problem
markjamespeters
Post by markjamespeters »
The drivers window on my 1994 import has stopped working. I have removed the door card to investigate and I am no wiser.
When the switch is activated to open or close the window, there is a voltage drop and I can here a click from the area of the window motor, which would suggest that power is getting as far as the solenoid.
Can anyone suggest if this is more likely to be a solenoid or motor problem and the method of changing either or am I barking up the wrong tree?
Return to “Electrical”
