Near death experience
Re: Near death experience
a good few have run 2 bar (or higher). Mostly the very high boost pressures will only be used for drag racing. I've ran 2.0 before on mine.
jimGTS wrote:
oh and if it was done at thor, that is 513 at the hubs, no quite the same as at the wheels....
Do you know what sort of ratio they differ by?
513BHP at the hubs
hub numbers are generally quite close to flywheel numbers...atw numbers to flywheel have more losses than hub to flywheel numbers, with the addtion of a wheel and tyre contact it would make sense...so 513 atw would be more power than 513ath...people say around 5-10% area difference between the two...
but your running enough power to not even worry about it, lol...
just my 2p..
is that only 200hp at 6500rpm?
I begining to think you have a problem locky lets get it on any time any where .
513BHP at the hubs
lmao,
no, more for people with crazy power mr2's
its just my old mr2 made 420hp at 6,500rpm 1.3bar
however your graph isnt very clear.
bigger pics
bigger pics
Chill out Locky just funning wija , by the way the run was made with shot gearbox , could only get 4+5 still went from 100bhp to over 5oobhp in a millllllllllisecond.
513BHP at the hubs
recognise your car - in fact, my cars even been it's neighbour for a couple of weeks before. hope she gives you plenty of big turbo fun over the summer. you got any plans to run it down the drag strip ?
Hi mate ---------only if Locky will be my running mate . Where do you know the car from ?
513BHP at the hubs
sure,
lets go on the 31st this month at santpod.
will be a laugh
will be a laugh
alan_watts wrote:Hi mate ---------only if Locky will be my running mate . Where do you know the car from ?
Your car lived with Xxxx for a while ... my car sometimes lives there too LOL.
Pretty sure Locky will be trying to get a good time in to get on the TOTB team. From what i've read, it's been wet when he's had a go so far, and that doesn't make for good 1/4's. Think his pal salamanzer will be trying to get some runs in before TOTB too.
When in the YSR car, i saw a little of what that motor of yours could do on the strip. If you've got it all running sweet, i expect you'll put in some really good times. Think it'd be an interesting and probably close "race". your T88 (drag king!) vs. GT35 (erm, drag queen - LOL - sorry locky couldn't resist that one).
i will be fun.
i wont have any slicks on this time, but i need practise.
this time the tyres will be lit up before runs, unlike last time
fine,
however i wont be running if its snowing,
please be my guest
please be my guest
Just for reference, your power fc will record the max boost pressures that you have run since you started the engine or reset the logging part of the system. You can see all tha values on the hand commander, it saves you staring at boost gauages when your accelerating rather quickly
Nice car BTW, i thought having a 1000kg Mk1 with 300BHP singled me out as nuts, that thing must be off the scale!!
When you crash it, can i have the engine
Sure thing Murf , just make sure you sing at the funeral .
513BHP at the hubs
