Yes this would solve your problem.
The wires that you need to tap into can be accessed by removing the plastic panel under the steering wheel and the removing the air vent piping which will become visible when the panel is removed.
You need to find a small box which says central locking control unit on it and trace the two wires that pulse to earth when the switch on the door is pressed
(you will need to press the courtesy light switch if the door is open as the car will not lock otherwise).
Also make sure your alarm is set up for negative switching central locking, i.e.
the two wires from the alarm pulse to earth for approx 1 second.
Hope this helps, Ian
