[Mk2] [Turbo] Getting there 530hp new spec
salamanzer
Re: [Mk2] [Turbo] Getting there 530hp new spec
Post by salamanzer »
i take it that you are running 87mm pistons the same as me... im hoping that the block doesnt crack on mine.
Have you not sleeved your block? I see that you have a girdle on the bottom end, where did you get it? I have only seen 1 company selling them in the states.
Jason
greeny
Post by greeny »
salamanzer wrote:i take it that you are running 87mm pistons the same as me... im hoping that the block doesnt crack on mine.
Jason
Jase,
Yep 87mm hks stroker pistons, no sleeves, keep our fingers crossed!
The block girdle is by medpilot(tyson) on MR2oc.com, think he sells them through twosrus. The skylines have had good results with them keeping the mains in check.
greeny
Post by greeny »
Salazammer
You running the hks 87mm hks stroker kit?
Apparently you can get hks to make 86mm versions with the same wrist pin height, Will be the way il go when/if the block cracks.
salamanzer
yes HKS 87mm.
I might sleeve the block if it cracks and get a girdle to stop any further cylinder wall cracking.
Jason
RyanRs
Post by RyanRs »
is yours a gen1/2 ? because if its gen3 ,the girdle wont fit .....
salamanzer
Mine is a gen 3. The one in the US will fit the block with some minor mods to the oil lines.
Anything that could extend the life of the block sounds good to me :D
RyanRs
Post by RyanRs »
your talking about the bottom end girdle yes? as in this pic??
because that will not fit! the problem with the gen3 is that the sump is partially bolted onto the gearbox.. using this girdle will put all of the sump/gearbox holes well out of line...
lockys96
Post by lockys96 »
:D
It started this weekend,
ive made a full under-carrage from fibreglass, and have moulded the off the front of my bumper for the fitting.
next up is too shape the foam to something i like.
will post the full project even if people dont agree;):D
RyanRs
Post by RyanRs »
looks good mate :thumleft: what did you use to cut the foam??
lockys96
Post by lockys96 »
i have a air saw,
thats just a rough cut
lockys96
Post by lockys96 »
:D24hrs on, nearly finished.
just need to prep, fill and paint.
going to have to trim the middle away, as its turnt out
a little heavier than planned:(,
will stick a sheet of carbon underneath when done.
just to fit some canards:)
[IMG]http://img244.imageshack.us/img244/4374/sdc10024os3.jpg[/IMG
Harry
Post by Harry »
Yes,loving It :twisted:
Tasty
Post by Tasty »
Hi have you road tested yet ,or am Ilooking in the wrong place. Irun a t88 and I find it fkng hard work to drive on the road ,is the gt35r any better for road work ? :?
513BHP at the hubs
RyanRs
Post by RyanRs »
a 35r will be better to drive on the road than the t88..but still by no means will it be road friendly!
even a gt3076r on the road is an animal!
salamanzer
Si,
Don't forget to add your dyno results to the garage :D
Hopefully I should be able to get my results up at the end of the month :D
Jason
lockys96
Post by lockys96 »
more power and torque.
look through my thread and there is a comparison on the dyno spool
t88 vs gt35r
splitter is finished and on the car, james has put the car back together.
is looking much more sexy under the engine and is well thought out.
look forward to getting here back and back on the dyno and crazy mapped on road.
depending on what happens, full-race full setup is next year.
james, post some pics of mr death-lip :mrgreen:
