[Mk2] [Turbo] st 205 charge cooler
LiamTye
Post by LiamTye »
hi all
got my charge cooler through today thanks to jimbo :thumleft:
at the minute its chrome and was thinking about painting it white and getting a black sticker made up like the original writing on top on it
here is how they look,could someone photoshop it in white please
does anyone know a list of parts i will need for the conversion wanna get most of the bits before i give it all to kent car craft for them to fit it
so far i know i will need: fiat chinky rad,st205 sock which i need the part number of,st205 support bracket which i have the part number for
any help with pipe work would aslo be gratefull
what is the wire for that comes out of the rubber gromet on top of the charge cooler,there is two wires
cheers pepps :thumleft:
karammander
Re: [Mk2] [Turbo] st 205 charge cooler
Post by karammander »
has been discussed lots on here , use the search function or you can use my name in the search as i've posted a little about chargecoolers.
cheers karam
Benmoore999
Post by Benmoore999 »
Liam, I am collating a parts list st the mo. Will keep you posted.
Ben
murf
Post by murf »
your better off using the st185 rubber sock as it doesnt need to be modded to fit.
read this : http://forums.twobrutal.com/showthread.php?t=12033
-:[KM]:-
Post by -:[KM]:- »
That's my engine bay!!
It's changed a bit since then...
LiamTye
Post by LiamTye »
it is i pinched the picture lol
LiamTye
Post by LiamTye »
km...just been told i may have a problem fitting the core i may need to move the bit that goes to the throttle body hosing as i have a rev 2 but see you do aswell so was wondering if you had any trouble fitting it
did you use a st205 sock or a 185 as im going to be ordering some bits for it soon
i got a few part numbers just wanna make sure
got part numbers for the sock,throttle cable bracket and support braket for the throttle body
-:[KM]:-
Post by -:[KM]:- »
It's the ST205 sock...
I've done a few now. All I do is extend the holes inwards to line up with the throttle body. If you look closely, I also taper the Allen bolt head (x4) to accomodate the rubber better. You'll have to look at the photo infull size...
LiamTye wrote:told i may have a problem fitting the core i may need to move the bit that goes to the throttle body hosing as i have a rev 2
Which 'bit' are you talking about?
LiamTye
Post by LiamTye »
i was told i may need to move the pipe that goes to the charge cooler from the throttle body if that makes sense which would mean cutting it apart which im not keen on but glad you put my mind as ease
when connecting the dump valve do i just need a bit of hose and thats it
do you remember what sort of hose i will need and how much to do the rad and pump etc
-:[KM]:-
Post by -:[KM]:- »
Cheapest hose I found without stealing it... enough for 3 CC installs!! :shock:
http://www.screwfix.com/prods/16429/Lan ... Y?ts=96621
And for the bends...
http://www.screwfix.com/prods/18598/Plu ... Pack-of-10
... to stop the hose kinking.
LiamTye
Post by LiamTye »
not sure on the yellow hoses but could get some black lol
ill show owen at kcc this post when i take the car to him so he knows what i will need
will you see the hoses or is it to go from front to back of the car for the rad and use the celicas hoses
ill get the link up for the charge cooler i bought so you can have a look
LiamTye
Post by LiamTye »
-:[KM]:-
Post by -:[KM]:- »
Yup... use the black celica hoses in the engine bay and the yellow underneath where they won't be seen.. :thumleft:
Don't go chopping any sock or CC away.. I do warm the in & out pipes underneath though, in order to put a 1/2" extension and twist them slightly to miss the coolant casting.
GL
LiamTye
Post by LiamTye »
just a thought but the 90 deg bends you put up are bigger than the pipe how do you fix them
im going to order aload of parts from mr t tomorrow and pop into screw fix and get all the stuff for it saturday
how is the charge cooler held down do the fixing points on the charge cooler line up anywhere on the engine
karammander
one of the mounting points come close on the cambelt side but the other two you need to get rid of since the coolant housing is in the way. they in and out pipes i found i needed to trim aswel as the cam cover breather, (if its a rev1)
cheers karam
p.s. these might help but not sure.
LiamTye
Post by LiamTye »
karammander...nice one cheers mate,a nice one one just what i want mine to look like
where have you mounted the over flow bottle thing
so is it just held done by the one fixing point then
trying to find something to cover the bottom with like heat sheild,looking on demon tweeks now cause the stuff on it now has seen better days
LiamTye
Post by LiamTye »
ive found this stuff will this be alright to use,im guessing by the look of it you just pull it back and stick it on
http://www.demontweeks.co.uk/products/P ... e=NIM14130
SFLee
Post by SFLee »
dont forget , you need a charge cooler pump, and a water expansion tank
LiamTye
Post by LiamTye »
i have the pump and got th expansion tank,its a tiny little bottle isnt it
LiamTye
Post by LiamTye »
bee looking more into this and have read a few people have been putting temperature sensors in the front for the charge cooler
this is the sensor i will be using as reccomended
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... PIC&ih=002
got to get something from maplins to convert the power sorce from 12 v to 5 v and wire it all up
was thinking on the plastic bit by the gear stick in the middle at the back and use bullet connectors so i can unplug it should i ever need to
was told about this for re lagging it as its falling apart at the minute so this should be suitable for the job and should have plenty to do it all
http://www.rallydesign.co.uk/product_in ... ts_id=1604
is there anything else i should need do you think to do the job thast not mentioned
