Well after borrowing a garage lift I managed the stand under the car and upon pressurising the whole cooling system to around 10psi noticed water dripping from just after the turbo heat shield
Well, thanks to reading Peter's
Here is the offending pipe that has caused me so much heartache and breaking down on cold nights in the rain for well over a year
![Image](http://img.photobucket.com/albums/v223/user116/mr2/pipes_from_hell1.jpg)
You can clearly see the amount of corrosion around the bracket and where the crack will be.
I'm going to see if I can drop the petrol tank out and cut away the offending bit of pipe and replace with a bit of silicon hose.
At present, I have bypassed the heater pipes completely by re-routing the first pipe back to the second pipe inlet, in a kind of
I really hope this helps you ppl!
![Very Happy :D](./images/smilies/icon_biggrin.gif)
