Started car today and it idled up to the more memorable 2500RPM.
The valve cap exists no more
![Shocked :shock:](./images/smilies/icon_eek.gif)
It was a good tight fit
![Embarassed :oops:](./images/smilies/icon_redface.gif)
what will become of it in the engine.
suggestions
un1eash wrote:The mod is part of doing the manual choke conversion but instead you drill a hole in the tyre valve cap to reduce air flow and revs, the valve goes in the throttle body..
http://i2.photobucket.com/albums/y17/un ... axstat.jpg
start with a small hole in the cap and increase to get the desired revs.
coverco wrote:Normally the start up revs are controlled by the AAV or waxstat, the hole where the valve cap is inserted allows air to pass thus decreasing the air to fuel ratio and increasing the revs.By inserting a valve cap with a hole you allow more air to enter the throttle body and so the revs decrease.
When the engine gets up to temperature the AAV closes and so no air goes through the valve cap so you are back to normal
I think this is how it works anyway![]()
Hopefully the following drawing should explain it better, click on it to enlarge.
http://i114.photobucket.com/albums/n266/coverco/AAV.jpg
viperrr wrote:coverco wrote:Normally the start up revs are controlled by the AAV or waxstat, the hole where the valve cap is inserted allows air to pass thus decreasing the air to fuel ratio and increasing the revs.By inserting a valve cap with a hole you allow more air to enter the throttle body and so the revs decrease.
Makes perfect sense now, I had no idea about that hole in the top too
Thanks!![]()
I put a holey valve cap in the right place and it seems to have done the trick- I am most pleased.
and I'm sure my neighbours will be at 7:30 in the morning too!
jimi wrote:
Not quite, the fuel/air ratio( at idle
is decided by the ECU acting on info from the MAP sensor.
Without the cap a certain amount of air passes through the port, the MAP sensor sees this and tells the ECU which increases the fuel accordingly and the idle rpm rises to around 2000/2500.
With the cap
(with a hole in it
) fitted then the amount of air passed is less because the hole is smaller, the MAP sensor sees this and tells the ECU which increases the fuel accordingly and the idle rpm rises to a level which is decided by the amount of air passing, so bigger hole
= higher cold idle rpm and smaller hole
= lower cold idle rpm.
If you go too small then your car won't idle properly when cold.
un1eash wrote:I made my own kit for about£5 from things lying around the garage.
I have thort about extending my manual choke to include a temp swtich and diesel relay so its only active for 10-20 seconds which is all thats need.
Assuming this is correct(I am sure it is) then why bother with a mechanical system like the AAV? Surely all that is required is a temperature sensor in the thermostat housing, as the engine gets up to temperature then the ECU could alter the fuel/air mix accordingly
