CM1GT wrote:i've always found a chisel and an adjustable spanner works fine
cantfindausername wrote:twosrus sell these for less than a tenner..
nofearmadbiker wrote:the ones advertised on ebay are lazerline have to see how much thay cost, cheapest ive found on ebay so far is£19 for that same tool.
only want to free up my nearside rear caliper as m.o.t tester said it was a bit slow just in case it gets any worse.
looking at rebuilding calipers anyway and adding uprated brake lines and maybe crossdrilled/grooved disc's mind you ive read on here that brakes are quite good as standard with decent pad's in them
Rowland wrote:CM1GT wrote:i've always found a chisel and an adjustable spanner works fine
Sounds like a recipe for impending doom.
I'm not overly fond of spending time at A&E..
