This is my story
i was running a bleed valve with no problems.
Changed to a grainger valve and at the same time put on a 2.5" downpipe.
The car was over boosting.
I was getting 8 psi until 4000rpm then it rose to 17psi.
We decided the fault was the downpipe and you could see marks where the wastegate flaps were catching it.
So i got a replacement and it looked a bit different.
This time the same was happening but i was getting 15/16psi which was fine.
Any way i fitted a cone filter and im getting 17/18psi.
I just took the gringer valve off and no change.
So is it the downpipe, the wastgate or the actuator.
Ive had the actuator tested and it seems ok.
i dont want to spend another
£200+ on anew downpipe and have the same problem.
Its just strange how i get 8 psi until 4000rpm and then by 4500rpm im hitting 17psi.
Someone help.
