is that normal?
does that mean this gauge is not going to be accurate?
gtech wrote:Yep thats normal on the Omori, which in fact are a very very accurate gauge.![]()
As a matter of interest, the other big names in Boost gauges get their mechanicals from Omori
If you need the fitting guide for this mod drop me an email at: [email protected]..
.Done loads of them and you wont have any problems.
robbie_742003 wrote:gtech wrote:Yep thats normal on the Omori, which in fact are a very very accurate gauge.![]()
Yep, deffo use this guys how to, i'm not the most technical of people but did this little mod in an hour or 2 being careful.![]()
Stef Derner wrote:I work with laser cutting machines and one of the tools in my toolbox is a very accurate 0 to 2 bar(abs) pressure gauge reading in 0.1 millibar increments
(or hPa, PSI).
I tested our Omori boost gauge before connecting it up as it too was reading slightly below zero.
The result was that the Omori was spot on, like 3sgte said, it seems the low atmospheric pressure is responsible, I'm quite happy that the gauge is accurate.
mattcambs wrote:Chr15py's Omori(same gauge) reads exactly the same.
He was worried about it too.
