Thanks,
Tim
Tiger Tim wrote:Changed the coolant over the weekend( replaced the water with coolant)
& all went well.
Followed the BGB.
Took it for a spin
& the needle never went above the vertical position.
I noticed that when I put the heater on full to HOT, there is very little heat.
Could there still be sone kind of air lock in the heater radiator.
The fluid came up the hose as per the BGB.
Thanks,
Tim
tonigmr2 wrote:Fear me, for I am watching
010on1986 wrote:Put a hose on the heater matrix bleed valve, open the valve.![]()
wet n dry vac the hose to suck out some coolant and air.
