The top nut on mine had 2-3 threads showing, had the same amount showing after i fitted konis.
I also put a spot of weld on mine so theres no chance of them working loose.
A pipe wrench and 4 foot pole makes quick work of getting those nuts off.
What inserts are you fitting? I didnt realise that with the originals the case makes up the shock housing.
You put coolant in to protect against corrosion and to aid in the heat transfer.
If you put to much in it'll just come out the top.
Also will come out if you lie them down so keep them upright.
