after having my engine light come on with fault 34 i reset the ECU and checked the boost presure and i'm running 1.6 bar of boost and as far as i know the car is stock could it be a faulty vsv?
You've definately got some problem there. Check all the pipe work, like the pipe from the turbo to the actuator. Be very carefull as that much boost on a rev1 will quickly end in tears.
You should have hit fuel cut before you hit 1.6 bar.??
My rev 1 had a split in the hose between the turbo and actuator and did this but my fcd was set to 15.5 psi so I never went as high as 1.6 bar.
I bet it flew
Zero
