[Mk2] [Turbo] how easy to swap from GT3071 to GT3582?
Owen @ Kent Car Craft
Post by Owen @ Kent Car Craft »
This is going to sound completely reversed to what i have been building for,but:
My external wastegate is vented through my drivers side vent.
With this in mind,how much work would i be looking at to swap to a GT3582 in the future?
I also run V'Band also.
Any ideas peeps?
EarL
Re: [Mk2] [Turbo] how easy to swap from GT3071 to GT3582?
Post by EarL »
What manifold do you have mate?
cantfindausername
Post by cantfindausername »
As long as they're both t3 footprint and same outlet style they exhaust will mount straight up. I would also think that the oil and water feeds would be the same. And from pics I've seen the compressor housing looks very similar, if not the same. I don'tthink you'd have much trouble swapping between them.
***RIP Car13 ***
*** Now in an Evo ***
EarL
Post by EarL »
cantfindausername wrote:As long as they're both t3 footprint and same outlet style they exhaust will mount straight up. I would also think that the oil and water feeds would be the same. And from pics I've seen the compressor housing looks very similar, if not the same. I don'tthink you'd have much trouble swapping between them.
What I was thinking Ant. I'll be fitting mine as soon as it arrives from across the pond, and the fit is more or less a straight swap. :thumleft:
EarL.
cantfindausername
I'm still waiting for mine to go on :cry: Will have to wait a hell of a lot longer too now if my ecu adapter doesn't come in :mad:
***RIP Car13 ***
EarL
Post by EarL »
cantfindausername wrote:I'm still waiting for mine to go on :cry: Will have to wait a hell of a lot longer too now if my ecu adapter doesn't come in :mad:
What ECU Ant?
*sorry to hijack the thread... *
cantfindausername
Hydra :thumleft:
***RIP Car13 ***
mikewright
Post by mikewright »
finally someone else with hydra! who's mapping yours. I thought about perfect touch but before i got a chance i blew the block on mine, so now i'm rebuilding it myself by the looks of it. Money went on the 1st build so if you have any advive i'm a great listener right now :)
mike
cantfindausername
Its a proper motorsports place up in Lincoln. :thumleft: Not quite your local tuner, but their work seems top notch. Not sure on price yet though.
***RIP Car13 ***
greeny
Post by greeny »
cantfindausername wrote:Its a proper motorsports place up in Lincoln. :thumleft: Not quite your local tuner, but their work seems top notch. Not sure on price yet though.
Got a link ant as im not far from lincoln myself.
Michael.
cantfindausername
Have PM'd you michael. :thumleft:
***RIP Car13 ***
I'm running an extemeboost exhaust manifold,
i dont know what footprint the GT35's are tho (?)
i'd imagine it would be ok to swap,anyone else?
EarL
Post by EarL »
Elmo Owen wrote:I'm running an extemeboost exhaust manifold,
From what Tim has told me, they come in various footprints, but the T3 is by far the most common, which is what my GT3071 and GT3582 are. Hence it being more or less a straight swap mate. Oil/coolant lines may be ever so slightly different location, but there should be no problem in fitting them.
I would be pretty sure yours is too. :wink:
EarL.
cantfindausername
The 35 is available in both T3 and T4, v-band and bolt-on exhaust housings.
I went for the T3 v-band for this very same reason - easily changable turbos.
***RIP Car13 ***
splashnatz
Post by splashnatz »
are you all planning on running huge injectors on these GT35's ? Also, what are your thoughts on suitable fuel pumps ?
cantfindausername
Mine will be small. :D :-$
***RIP Car13 ***
V8Killer
Post by V8Killer »
splashnatz wrote:are you all planning on running huge injectors on these GT35's ? Also, what are your thoughts on suitable fuel pumps ?
A GT35R at full whack is likely to maximise the limits of a Walbro. Upgrading to a Bosch 044 Motorsport / Aeromotive A1000 would be a better option! Or, better still go down the low pressure lift pump, high pressure in-line pump, swirl pot setup :D
M5
tonigmr2
Post by tonigmr2 »
GT35R - my injectors are pretty much at their safe limit - they are 800cc...(I mean there is no more room there and I need bigger!)
T
EarL
Post by EarL »
I have 870's in mine, and Dave has already said that they should be fine... for now. :wink:
splashnatz
really earl ? i would of thought 1000cc plus would be needed to get the best out of the turbo ?
think if it was me, i'd go the v8killer route of extra high flow pump and throw in some even bigger injectors.
